How can the instance number be changed in a Viconics BACnet thermostat?
  • How can the instance number be changed in a Viconics BACnet thermostat?
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:44 PM
No visible button to enter configuration
The ID or instance number is 7x000(x=series model)+ Mac address. The Mac address can be defined from the front of the unit. Press the white "config" button in the lower right hand corner of the circuit board once. Then keep hitting "no" until "Com Addr" is displayed and hit yes. Use up/down keys to set the address.
For units with no white "config" button:
  • VT7200 series press and hold the button (OVERRIDE) for 8 seconds
  • VT7300 series press and hold the middle button (°C/F or OVERRIDE) for 8 seconds.
  • VT7600 series press and hold the button (MENU) for 8 seconds
Then press no until "com addr" displays, then press yes and use the up/down button to change it.
  • TAC IA Series
  • 3163
