Explain and define I/NET Ethernet, C-LAN, and Sub-LAN communication
  • Explain and define I/NET Ethernet, C-LAN, and Sub-LAN communication
‎2018-09-07 05:44 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:03 AM
  • What is the SubLAN and what is the C-LAN in regards to Ethernet and termination resistor information?
  • Explanation of termination resistor, RS-485, baud rate, token passing, and polling method.
  • Is the Host LAN above or below the Ethernet LAN?
TAC INET
I/NET Seven Network
A better understanding of the I/NET network architecture and communication components can help to avoid the need to troubleshoot issues later.
When defining the network in I/NET, the chart below helps to explain which components communicate to others including resistor termination. This is a simple explanation on where the various I/NET components are located in an I/NET Seven Network. C-LAN & Sub-LAN Wiring Specifications are available here as a PDF document.
Selecting the link Network Definition CLAN SubLAN downloads and opens the pdf document shown below.
  • TAC INET
Tags (16)
  • 4551
  • architecture
  • awg
  • bus
  • cable
  • capacitance
  • configuration
  • diagram
  • distortion
  • drawing
  • fiber
  • foi
  • repeater
  • speed
  • structure
  • traffic
100% helpful (1/1)
