UI inputs of the MNB-1000 do not support pulse inputs
  • UI inputs of the MNB-1000 do not support pulse inputs
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 01:18 PM
Do the universal inputs (UI) of the MNB-1000 support pulse inputs?
TAC IA Series
MNB-1000
Attempting to wire a pulse input to a UI on the MNB-1000 can cause issues.
The UI inputs of the MNB-1000 do not support pulse inputs and can not be used for this purpose.  The digital inputs (DI) of a MNB-1000 do support pulse inputs.
Pulse Input Rate
  • Minimum rate of 1 pulse per 4 minutes
  • Maximum rate of 10 pulses per second
  • TAC IA Series
  • 6154
