Creating custom Multi-state Text definitions
  • Creating custom Multi-state Text definitions
  • SESA116857
    SESA116857
‎2018-09-06 03:28 PM
Vista 4.2x Workstation
"Value-Multi-state" objects in Vista have a property called Multi-state Text which provides the definitions to enumerated signals. This is similar to the paired text in a "Value-Binary" signal. However you cannot add a new entry in the Vista 4.2x workstation.
To add a new entry to the drop down list:
  1. Navigate to C:\Program Files\TAC\TAC Vista\
  2. Find the old workstation program tamain.exe
  3. Use the object selection dialog to select the Object Type filter of "Multi-state Definition"
  4. Add a new definition by following the naming convention of the existing definitions.
  5. Once you have added the definition, edit the object and enter the text values in the “MSTXTS” field separated by comma in the order that match the enumerated signal. Example: OFF, ON SECR, UNLK, LOCK
  • 991
