Computer will not recognize NIC709-USB
  • Computer will not recognize NIC709-USB
  • Trey_Boothe
    Trey_Boothe
‎2018-09-06 09:42 AM
When trying to install a NIC709-USB the computer will not recognize it.
  • Vista
  • LonMaker
  • NL220
  • Windows 7 64-bit
  • Windows 2008 Server 64-bit
A NIC709-USB will not work with a 64-bit OS.
If you have a 64-bit OS then you must use a NIC709-USB100 instead of a NIC709-USB.
Tags (2)
  • 15597
  • see
