Fiber Optic Interface, Ethernet, C-LAN, and Sub-LAN communication.
  • Fiber Optic Interface, Ethernet, C-LAN, and Sub-LAN communication.
‎2018-09-07 03:43 AM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:57 AM
What is the SubLAN and what is the C-LAN in regards to Ethernet and termination resistor information? Explanation of termination resistor, RS-485, baud rate, token passing, and polling method.
Is the Host LAN above or below the Ethernet LAN?
TAC INET
I/NET Seven Network with integration of the FOI or Fiber Optic Interface
How the Fiber Optic Interface (FOI) fits into an I/NET site.
When defining the network in I/NET, the chart below helps to explain which components communicate to others. This is a simple explanation on where the various I/NET components are located in an I/NET Seven Network. C-LAN & Sub-LAN and the integration of Fiber Optic or FOI. The FOI Spec sheet is available here, as well as TCON087.
Click the image below to download as a PDF document.
  • TAC INET
  • 3904
