Changing Report Server "appuser" password
  • Changing Report Server "appuser" password
‎2018-09-11 08:26 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:36 AM
Information needed about how to change the "appuser" password used by the Report Server Agent
Web Reports
Warning
There is no information available on whether the Web Reports "appuser" account password can be changed and how it's done
NOTE: Refer to the following article Report Server "appuser" clarification for additional information on the appuser
The password defined for the user in the configuration file needs to match the actual password in the operating system.
To change the password, do the following
  1. Stop the WebReports Agent service
  2. Change the password defined for the "appuser" in Windows
  3. Change the password defined for the "appuser" in the WebReports Agent config file:
    C:\Program Files (x86)\Schneider Electric\StruxureWareReports\StruxureWare Reporting Agent\SE.WebReports.StruxureWareReportingAgent.exe.config
  4. Restart the WebReports Agent service
Tags (2)
  • 17815
  • RobertAndriolo23
