Can Continuum operate over a NAT Ethernet connection?
  • Can Continuum operate over a NAT Ethernet connection?
  • PaulFr
    PaulFr
‎2018-09-06 12:53 PM
Can a workstation communicate to a controller using Ethernet Network Address Translation (NAT)
Andover Continuum
  • Cyberstation
  • All Ethernet level CX and bCX controllers.
Some IT Departments may want to use Network Address Translation to connect between different sections of their network.
Continuum does not support Network Address Translation (NAT) the IP address entered in the Cyberstation database must match the address entered locally in the controller.
  • 6943
100% helpful (1/1)
