BioScrypt V-Pass-2 (Biometric) Reader in I/NET Seven
  • BioScrypt V-Pass-2 (Biometric) Reader in I/NET Seven
  • Tom_Poovey
    Tom_Poovey
‎2018-09-07 02:32 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-26 12:47 PM
How to program a BioScrypt V-Pass-2 (Biometric) Reader in I/NET Seven.
Other, TAC INET
I/NET Seven
BioScrypt V-PASS (MV1200)
Assistance with configuring the BioScrypt V-PASS reader with I/NET Seven Access Control.
Biometric Reader Setup
Using the Bioscrypt V-pass-2 Reader
The reader is:
Bioscrypt V-Pass FingerPrint Reader VPASS-2
Note: The Programming software to load fingerprints on the PC comes with the reader.
For the actual wiring and programming of this reader see the linked "BioScryptSetup.PDF" BioScript Setup
Wiring (pigtail)
Wiegand
1 - Wiegand Out Data 0
3 - Wiegand Out Data 1
6 - Wiegand GND
Power using separate 24V DC Power Supply
11 - Pwr GND
13 - Pwr IN
15 - Earth Ground
BioScrypt V-Pass Reader Wiegand Setup
Install BioScrypt Software (VeriAdmin) on PC and setup to communicate with reader.
  1. Go to Configure > Unit Parameters
  2. Click on Wiegand Tab
  3. Check Predefined Format
  4. Pick "Standard 26 bit"
  5. Under On Success
  6. Check Alt Site Code & Enter Arbitrary Value (usually 3 digits)
  7. RECORD VALUE this is the Site Code
  8. Under Wiegand I/O
  9. Check Enable Input
  10. Check Enable Output
  11. Select Always Output (regardless of Input Source)
  12. Enroll Individual in VeriAdmin
Enroll Individual
RECORD ID – this is Individual Number
NOTES: The index number is to assigned to ID number to record each individual finger (0-9 is for all 10 fingerprints). I/NET will only be sent the ID number in the Wiegand String.
Schedule does not matter. You have selected Always Output (regardless of Input Source). One will do all the door scheduling in I/NET.
Enroll Individual in I/NET
Create new Tenant called “BioReaders”
If site is using Wiegand Card and NOT Large Numbers (Dipswitch 7 OFF)
Enter Site Code (recorded from above) as the Tenant ID
When enrolling the individual in the new tenant, use the ID recorded from above as the Individual Number and Decimal Card Number.
If site is using Wiegand Cards and Large Numbers (Dipswitch 7 ON) or if using Idiscs (set Dipswitch 7 ON for only DPUs with BioScrypt, even if they have Idisc also)
Leave default Tenant Code.
Use 26BHEXCAL.xls and enter Site Code and Individual ID recorded from above and it will generate the HEX Card Number.
When enrolling the individual, enter the Hex Card Number as generated.
I/NET Door Configuration
Make sure door is setup as Wiegand 26
Configuration as Implemented
DPU 7920
Door 08 was setup as BioScrypt V-Pass MV1200
Door 09 was setup for Idisc
Door Lock was wired to both relays in series (so both had to be energized to unlock the door).
Door 08 (BioScrypt) was given a schedule of 24/7 and assigned to all individuals in new tenant.
Door 09 (Idisc) had the original schedule assigned to site personnel.
This schedule is the one that will deny access according to schedule.
Other Configurations
This can be used as a single reader for the door (with schedules in I/NET) or as implemented above with any combination of reader compatible with I/NET.
  • TAC INET
  • 2887
