Batteries for the UNC-410 and UNC-520 are interchangeable
  • Batteries for the UNC-410 and UNC-520 are interchangeable
  • WaynePeters
    WaynePeters
‎2018-09-06 01:15 PM
Are the batteries for the UNC-410 and UNC-520 interchangeable?
TAC IA Series
I/A Series R2, UNC-410, UNC-510, UNC-520
Replacement batteries are needed and compatibility between devices must be known.
The batteries used in the UNC-410, UNC-510, and UNC-520 are the exact same and are interchangeable.
The replacement part numbers UNC-400-BAT and UNC-500-BAT include the same battery.
  • TAC IA Series
  • 6252
