Forta Adapter for Honeywell Valves
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Forta Adapter for Honeywell Valves
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
timkelly
Lieutenant JG timkelly Lieutenant JG
Lieutenant JG
Posted: ‎2021-08-16 05:36 AM
2524
Hi Folks,
I have a Honeywell valve with a non functioning Honeywell Actuator that I would like to replace with a working Schneider Electric actuator.
Does anyone know if there is an Adapter Kit for a Honeywell V5016A1036? Is there a catalouge or list of the Adapters Schneider Electric supplies? After a long search, I couldn't find anything.
  • Traditional Valves and Actuators
Simon_Firth
Lieutenant JG Simon_Firth Lieutenant JG
Lieutenant JG
Posted: ‎2021-08-16 05:59 AM
2522
Hi, Information on linkage kits to other manufacturers is not so easy to locate.
But we do have a solution, linkage kit 8800116000 fits to all the common Honeywell globe Valves with a 20 mm or 38 mm stroke.
This kit will fit the V5016A valve.
02-00056
Mr Valve
timkelly
Lieutenant JG
Posted: ‎2021-08-16 06:28 AM . Last Modified: ‎2021-08-16 06:29 AM
In response to Simon_Firth
2517
Hi and thanks for the link.
We had the 8800116000 kit and the bonnet fit, but the nut for the Valve Stem was too small. These are 1/4" or M6 and I think the Honeywell stem has a 13mm nut. I have ordered the AV822 kit for the nut to see if it works.
Thanks Again for the reply.
Tim
Simon_Firth
Lieutenant JG
Posted: ‎2021-08-16 07:20 AM
In response to timkelly
OK - please keep in touch on the matter
Mr Valve
