EBO Web Services - XML
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
Showing results forΒ
Did you mean:Β
  • EcoStruxure Building
  • Intelligent Devices
  • EBO Web Services - XML
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
imichalrodak
Crewman imichalrodak
Crewman
Posted: β€Ž2025-02-01 01:13 AM
1452
Hey,
I can't cope with addind XML Web Services to EBO (AS-B automation server). I think I'm doing everything properly (taking care of final forward slash, encoding is in a right format), but my service is still offline. Ofc I have turned EWS on etc. But it looks like it doesn't even "think" or try to connect, it's just permanently offline (values are 0, xml response is empty), I don't know, maybe some setting is set in the wrong way...
Thanks in advance!
  • Others & accessories
imichalrodak
Crewman
Posted: β€Ž2025-02-03 08:51 PM
Hey! Seems like I found the solution! πŸ™‚ the issue was an Internet connection, I got my network switch connected directly to router and it lifted off immediately. Honestly, I thought EWS would work pro tem, when AS connected to the computer with Internet connection, but nope.
Thank you again guys!
Replies 5
MikaelKrantz
Guinan
Posted: β€Ž2025-02-02 11:27 PM
Looks like you do have an alarm: naruszenie zasad licencjonowania
Could it be that you do have a license issue here that needs to be solved first?
Web things will not work without license.
CraigEl
Posted: β€Ž2025-02-03 12:39 AM
1423
@imichalrodak I also see that you seem to have a DNS error alarm for the address in your web service
Make sure that you have specified a DNS server in your AS server network configuration.
imichalrodak
Crewman
Posted: β€Ž2025-02-03 12:55 AM
In response to CraigEl
Hey guys, thank you for your answers!
@MikaelKrantz yeah, there was an issue with AS' license, already up to date and still the same...
@CraigEl I have specified DNS - Google and Cloudfare (3 different in total), but I've notice I had the default gateway space empty, thought It could be the reason - specified and still nothing 😞
I was even wondering if there was a problem with this specific API, but tried with totally different ones, also offline. I will still rummage everything possible today, but I already run out of ideas πŸ˜…
imichalrodak
Crewman
RomanWalker
RomanWalker
Cadet
Posted: β€Ž2025-02-04 02:15 AM
I also had the same issue.
Β
