Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
Posted: 2025-07-06 05:13 PM
Can we use the mobile app wiser home to change the temperature of the se8000 remotely while the SE8000 is also connected via BACnet MS/TP to a Spacelogic controller?
Anyone tried that and could provide some guidance on the process?
Posted: 2025-07-06 11:12 PM
@Izak2025 I don't believe that the SE8000 is compatible with the Wiser app
Posted: 2025-07-07 06:42 AM
Hi Craig,
There is a tutorial on the forum using the MPM.
The only questions, I`ve got is if this can run in parallel with a BACnet MS/TP connection. Also, where can I get a MPM as it`s now discontinued.
Posted: 2025-07-07 11:22 PM
@Izak2025 I think you already know the answer...this guide is 10 years old and the MPM is no longer available, I'm not even sure that the Wiser app is the same as the one noted.
Hi Craig,
Posted: 2025-07-07 03:44 PM
There is this article. Is it not possible to do it that way?
