Compliance on EPP sensor
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Compliance on EPP sensor
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
Suchithra
Crewman Suchithra Crewman
Crewman
Posted: ‎2023-08-11 12:28 AM . Last Modified: ‎2023-08-13 10:15 PM
1571
Supply, Installation, Testing, Commissioning of Room low Differential pressure transducer, the sensor shall measure Exact measurement of positive, negative and differential pressures. The sensor shall be Static dual-membrane-pressure sensor on capacitive basis, Can be fitted in any position. Range of ±100 Pa. This shall include nozzle & 20 Mrt of PU tubing
Does our EPP sensor comply to the above description? Please confirm.
  • Pressure Sensors
Suchithra
Crewman
Posted: ‎2023-08-17 09:01 PM
EPP used a single pressure sensor.  It can determine pressure  "OR" velocity but not both at the same time. It is a single semiconductor capacitive device.
Suchithra
Crewman
Posted: ‎2023-08-13 10:12 PM
1543
Can anyone confirm whether the EPP sensor has dual membrane on capacitive basis
CraigEl
Posted: ‎2023-08-16 05:14 PM
In response to Suchithra
@RishuSingh are you able to assist?
Suchithra
Crewman
