uM221 with HMIST6500
  • Industrial Automation
  • uM221 with HMIST6500
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Operator Terminal Expert 3.1
Logic Controller - Modicon M221
Sophearak
Ensign Sophearak
Ensign
Posted: ‎2024-01-14 08:46 PM
981
Currently, we need to use HMIST6500 to linke with M221 and I want to use serial communication via Modbus RTU.
Thanks for advice
  • Process Automation Talks
Bastian_Schmitz
Admiral
Posted: ‎2024-01-14 11:49 PM
Ok, that is in general absolutely no problem, what is you question?
You use the SE Modbus SIO Master driver
and then you could import the smybol link file from you ESME Basic project
best regards
Bastian_Schmitz
Admiral
best regards
