problem SOMOVE root element is missing
  • Industrial Automation
  • problem SOMOVE root element is missing
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2020-08-26 01:19 PM
7881
Somove version 2.8.2.0
So basically i'm just trying to configure my com option in SOMOVE so my rs485 adapter can communicate with the LXM32M
We Just changed computer here and the other computer were working fine. But this computer is on windows 10.
Everytime that i click on the gear for advanced option on the top right corner of the window. the message
root element is missing.
So at first i tried a few different things, i didnt work.
Then i decided to completely uninstall so move and DTM LXM32 library just to make sure.
After restarting computer, i went on schneider website to redownload somove and the dtm.
Unfortunately i still have the same issues.
I would be happy if someone can help
Best regards
  • configuring
  • control
  • drive
  • element
  • it
  • linear axle
  • lxm
  • programming
  • root
  • schneider
  • somove
  • ti
Posted: ‎2020-09-18 05:33 AM . Last Modified: ‎2020-09-18 05:34 AM
4
7756
The only way it would work was by desactivating all the other USB and Port on the PC.
Talk about it with Schneider to finally discover that was a bug in version 2.8.2 of so move. So i downloaded the version before which is 2.7.5. Now it is working flawlessly..
Replies 6
Posted: ‎2020-08-28 11:01 AM
my technical representative found this but this does not work for me.
https://www.se.com/ww/en/faqs/FA365159/
4
7757
Fleo
Ensign Fleo
Ensign
Posted: ‎2021-01-11 04:51 AM
In response to Anonymous user
I recently encountered the same problem.
However I use SoMove version 2.6.5.
So I don't think this is a bug in SoMove.
I guess the problem appeared on my computer when I installed EcoStruxure Machine Expert Basic 1.1 Patch 1 which updated the serial Modbus driver to version 14.15.
This new driver created a Windows user account named SE-Account, dedicated to driver management.
To make the driver work properly, I had to remove the Windows autologon. And I'm waiting a little bit before logging in to give the driver time to start.
I don't like this situation but I haven't found any other solution.
Going back to an older version of SoMove you probably also changed the Modbus driver version.
Posted: ‎2021-01-25 04:55 AM
2
7174
Try restart NetAccess service.
Fleo
Ensign Fleo
Ensign
Posted: ‎2021-02-11 05:25 AM
7056
Thank you very much Kolod for your tip with NetAccess.
Indeed I already tried to restart this service before you mentioned it... But I couldn't. I thought I had lost admin rights with this service (related to SE-Account).
I tried again after your message and it worked!
So I made several tries and I found that this service (and others) is very long to start after Windows bootup. When the service is in "starting" status, it's not possible to stop it (unless I use a kill command). But when the service reaches the "running" status, I can easily stop it and restart it.
Well, now I'm looking for the cause of abnormal slowness of communication related services. Maybe the domain administrators pushed some changes to my computer, which had an impact on Schneider's services and drivers?
Drago
Drago
Cadet
Posted: ‎2022-03-30 03:10 AM
In response to Fleo
Restarting the Net Service worked for me too. Thanks for the tip. I'm using 2.9.2.0 on a Win7x64 VM. I also had it installed on a Win10 VM and I had the same problem. It only started happening after I upgraded to 2.9.0
