Zelio Soft boolean parameter box display
  • Industrial Automation
  • Zelio Soft boolean parameter box display
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2022-08-28 08:04 AM
4
1341
Hello
I Works with Zelio soft version 5.4.2
in the parameter window of a Boolean function, I cannot see the configuration.
thank you
Richard
Replies 4
iznobe
Crewman iznobe
Crewman
Posted: ‎2023-10-04 09:10 AM
Hello , the parameters box works is enties are connected only
KarlDixon
KarlDixon
Cadet
Posted: ‎2025-07-14 04:24 AM
I was having this same issue as well when I installed the latest version on windows 11. I pulled my old laptop out with windows 10 and it displays properly. Still annoying and needs to be fixed for a future release. I dont think the person replying above understood the issue. Even with inputs connected the outputs column doesnt show in full and theres no way of altering the size of the columns or the window.
Bastian_Schmitz
Admiral
Posted: ‎2025-07-14 09:50 PM
452
I could not reproduce the problem. I use also Windows 11 and 5.4.2. Zelio logic. But in a different language. You could try to adjust the scaling level of you display in the windows display configuration. I use at the moment 125%
KarlDixon
KarlDixon
Cadet
Posted: ‎2025-07-15 02:07 AM
In response to Bastian_Schmitz
I had the scaling level set to 100% so I have changed it to 125% as you suggested. It hasnt made any difference I still cant see the output column.
