What analog input value should I use?
  • Industrial Automation
  • What analog input value should I use?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Modicon M580
EcoStruxure™ Control Expert
gretarmark_
Ensign gretarmark_
Ensign
Posted: ‎2022-12-09 05:56 AM
2042
Hey, I am using a AMI0810 analog input module in Control Expert. What value should I use for regular analog measurement from a sensor? (See the image below)
I was thinking about using .FCT_TYPE because it is of a type WORD, but I think I can also use .ANA.VALUE but that is of type INT.
It would also be good to get a description of alla of these opt ions that one channel offers.
  • Training
Robert_Willis
Lieutenant JG Robert_Willis Lieutenant JG
Lieutenant JG
Posted: ‎2022-12-09 06:39 AM
2036
The proper one to use the .value sub variable for the analog value which is scaled as a INT based on the channel configuration. I have created a DFB that will take the T_U_ANA_STD_CH_IN into a DFB and I then use the AALARM DFB from the General-Purpose Library to provide the alarming.
Robert_Willis
Lieutenant JG
2037
gretarmark_
Ensign gretarmark_
Ensign
Posted: ‎2022-12-09 06:45 AM
In response to Robert_Willis
Thank you for the answer Robert.
