Vijeo Designer window layering
  • Industrial Automation
  • Vijeo Designer window layering
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
ceffet
ceffet
Cadet
Posted: ‎2024-10-22 02:44 AM
672
I'm working on a project in Vijeo Designer (v6.2.5 SP5.1) and I'm running into a layering issue with pop up windows. When looking at for instance, a pump pop up, and you hit the start button, an additional confirmation pop up is called up that says "are you sure, etc..".
The problem I'm having is that the confirmation pop up is showing behind the equipment pop up so you can't see it. Or sometimes it shows up on top, but when you hit 'yes', it immediately moves behind and doesn't register the button press, so you have to close the first pop up and hit it again. There doesn't seem to be a layer setting that I can find that would dictate this behavior. I've actually seen this in the Vijeo simulator a ton of times, but it's always just worked correctly when I push the program to a physical touch screen, so I just figured it was just an issue with the simulator. Now it's doing it on a Magelis I'm working with.
10.0.0.0.1 192.168.1.254
  • Process Automation Talks
  • Training
ajrhe
Ensign ajrhe
Ensign
Posted: ‎2024-10-23 05:25 AM
You'll get different results using On Touch vs On Release actions. Try both.
