Trouble Getting Data From a Modicon PLC With Unity Developer's Edition
  • Industrial Automation
  • Trouble Getting Data From a Modicon PLC With Unity Developer's Edition
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Control Expert
calicontrols
calicontrols
Cadet
Posted: ‎2023-04-27 12:45 PM
I am writing a .NET 6 console application that uses the Unity Developer's Edition (UDE) COM API to automate some Control Expert features. So far I have successfully used UDE to connect to a Modicon M340 PLC over TCP/IP, transfer the PLC's project to my PC, and save the project to my hard drive as an STU file. Next I am trying to save the PLC's data to my PC with UDE's IProject::SaveDataFromPLC method, but this method consistently returns an error.
The error is a System.Runtime.InteropServices.COMException that contains no information other than a hexadecimal error code: 0xE8A72CED. I could not find any information about this error code online. Microsoft's Error Lookup Tool returns the following:
# No results found for hex 0xe8a72ced / decimal -391697171
# anonymous HRESULT: Severity: FAILURE (1), Facility 0x8a7, Code 0x2ced
# for hex 0x2ced / decimal 11501
WSA_PNRP_CLOUD_NOT_FOUND p2p.h
# 1 matches found for "0xE8A72CED"
From my googling, WSA_PNRP_CLOUD_NOT_FOUND is related to peer-to-peer networking, but because the Error Lookup Tool says there were no results found for the full hex, I am unsure whether WSA_PNRP_CLOUD_NOT_FOUND is relevant.
My console application is written in C#, and I worry that I am passing invalid arguments to IProject::SaveDataFromPLC. Here is the method I wrote that takes the Control Expert project and a file path as arguments and invokes IProject::SaveDataFromPLC to save the project's data to the file path:
public virtual void SaveDataToDisk(IProject project, string resultDtxPath)
  int[] saveDataParameters = { 1, 0, 511, 1, 0, 1023, 1, 1 };
  object used;
  project.SaveDataFromPLC(resultDtxPath, saveDataParameters, out used);
This method is invoked after acquiring the write token to the project and saving the project STU to my hard drive. The error occurs in this method on the line that invokes project.SaveDataFromPLC.
Any advice on things I may be doing wrong or on other available methods to automate saving the data from a Modicon M340 PLC would be greatly appreciated.
Thank you!
  • Smart Design & Engineering
  • Smart Operations
Replies 0
