Posted: 2021-07-27 09:04 AM
I'm facing a problem with my SoMachine expert , I've this problem since the first install , I've reinstall it multiple time to repair.
When I'm working with frame I've the property dialog box on the right (The problem is the same even if I put the box on the left top bottom). When I try to change the width of the column the cursor change when I click , I can slide I can see the vertical bar moving but when I release the mouse button the vertical bar return to the origin and the width don't change.
Here is a screen capture of my property dialog box.
Thanks for your help.
Sébastien
