Control Expert V14.1 DDT Data Editor
  • Industrial Automation
  • Control Expert V14.1 DDT Data Editor
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2020-03-26 05:51 PM
7761
Has anyone experience the following and know how to prevent it from occurring?
When re-ordering elements within a DDT Structure in the DDT Data Editor the comment of the element that is moved disappears.
  • Smart Design & Engineering
  • Data Editor
  • DDT
  • Disappearing Comments
MarkPitout
Lieutenant JG MarkPitout Lieutenant JG
Lieutenant JG
Posted: ‎2020-12-07 09:50 PM
In response to Anonymous user
6178
The response I got on this topic (case nr: 67577823):
This is scheduled to be correct in Control Expert V15.0
Replies 9
MarkPitout
Lieutenant JG
Posted: ‎2020-03-27 06:24 AM
7745
Hi @Anonymous user ,
My DDT editor does not behave the same as your's at all - when dragging elements of the DDT around, Control Expert actually makes copies of the elements. It does not reorder the elements.
However, those copies do not contain the comments of the element original elements.
See my video attached
Posted: ‎2020-03-29 02:15 PM
In response to MarkPitout
7703
Hi @MarkPitout,
Clicking and dragging items will duplicate items.
Pressing shift before releasing the mouse button will instead move items.
MarkPitout
Lieutenant JG
Posted: ‎2020-03-31 05:50 AM . Last Modified: ‎2020-03-31 05:50 AM
7662
Okay. Did the shift-release thing - my Unity behaves the same as yours (comments are removed from the variable once moved).
I'll see if I can raise a ticket for this - given that this behavior isn't critical to how a PLC runs the code, I don't expect it will be high on the developers list of priorities. But let me raise it none the less. perhaps it will be sorted in a future hotfix or release
Posted: ‎2020-04-02 04:39 PM
Hi @MarkPitout,
Correct it doesn't affect the behaviour of the PLC code however, from a development point of view it reduces productivity as you need to re-add comments if a change is made.
Posted: ‎2020-06-24 03:24 PM
7067
Hi @MarkPitout,
Did you end up getting a response from the ticket that you raised regarding this?
MarkPitout
Lieutenant JG
6179
Posted: ‎2020-12-07 10:01 PM
Hi Mark,
Thanks for following up.
Posted: ‎2021-08-18 06:38 PM
4581
Hi @MarkPitout,
I've just tried this in Control Expert V15.0 SP1 and the issue has not been resolved.
Posted: ‎2021-08-19 01:06 AM
Hi @Anonymous user,
Sadly you are correct - the bug is still there. I reproduced it myself in V15.0 this morning.
BTW I no longer work at Schneider Electric - I now work at a system integrator. But, one of my ex-colleagues at Schneider did contact me about this thread today - hopefully the software developers will look into it for the next hotfix or service pack.
