SoMachine M251 RAM Battery Monitoring
  • Industrial Automation
  • SoMachine M251 RAM Battery Monitoring
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
ryanAstiefes
Ensign ryanAstiefes
Ensign
Posted: ‎2023-12-19 02:50 PM
830
How do I monitor the Ram Battery in SoMachine?
I've tried using the PLC_GVL.PLC_R.i_wClockBatterystatus on a GT block but I keep getting compiling errors.
What must take place in order for me to be able to use this Variable in a POU?
  • Process Automation Talks
LeTomas
Lt. Commander
Posted: ‎2023-12-21 12:14 AM
HI @ryanAstiefes ,
You can try like this without the PLC_GVL:
But it also worked for me:
Maybe you will need to share the compiling error to know more about the problem. If it is related to the syntax , the variable or the block.
Best regards,
Leandro
dnordenberg1
Lt. Commander dnordenberg1
Lt. Commander
Posted: ‎2025-03-20 01:08 AM
Btw, just so you know, the battery is not for RAM, it is for the RTC clock only so PLC will not die at power loss without it 🙂
