Setting up multiple speeds on Altivar using SoMove
  • Industrial Automation
  • Setting up multiple speeds on Altivar using SoMove
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
targe
targe
Cadet
Posted: ‎2024-06-28 04:08 AM
613
Hello everyone, sorry if this is the wrong place, but I am trying to set up an ATV320 and I want DI1 and DI2 to control different speeds, I'm a novice with SoMove but I have a dozen or so drives to setup and the idea of being able to make one program and copy it onto the rest appeals. Any advice on setting this up would be gratefully welcomed.
192.168.0.1 router login
  • Process Automation Talks
BJacqz
Commander BJacqz Commander
Commander
Posted: ‎2024-08-22 02:25 AM
Yes,
You can create a project "offline" using SoMove, then you will be able to downlod it in the product, you have to use a SoMove cable, or if you do not have use an ethernet cable if you have possibility to connect on your product.
Hope it helps
Bruno Jacqz, Drives training leader
