RTC48 latched output configuration
Send InviteCancel
Posted: 2022-06-2105:10 AM
Please I am in an urgent situation with an important customer and there is a requirement to adjust the contact reset type to be latched contact and the manual isn't clear enough if this function is applicable or no and the procedure to configure it if applicable.
