Operator Terminal Expert : Index 0 DropDown List
  • Industrial Automation
  • Operator Terminal Expert : Index 0 DropDown List
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Operator Terminal Expert 3.1
rfond
Ensign rfond
Ensign
Posted: ‎2025-02-26 03:09 AM
2038
Hello everyone,
I have another issue with EOTE. I have a selectable dropdown list, and I want to use index 0 from this list (my selection options are 0 = Stop / 1 = Auto / 2 = Manual). The problem is that the index always starts at 1. This is a big issue for me.
How can I use index 0?
Thanks!
  • Process Automation Talks
  • eote
Replies 10
Hennie_Smith
Lieutenant Hennie_Smith Lieutenant
Lieutenant
Posted: ‎2025-02-26 09:32 PM . Last Modified: ‎2025-02-26 09:33 PM
Hi unfortunately there is no way the dropdown object to start with index 0. If this is on a faceplate (popup) you can probably add an additional 'Accept/Ok' button to write the (selected index - 1) to the PLC variable. Convertors will also not work as it can only convert direction PLC -> HMI and not the other way around.
rfond
Ensign rfond
Ensign
Posted: ‎2025-02-27 01:45 AM
Are any fixes planned for this version?
Is there a roadmap for EOTE's future development?
Hennie_Smith
Lieutenant
Posted: ‎2025-03-16 10:38 PM
1950
EOTE is the software that will be used going forward on all new HMI models. It is active product and regular updates are released.
rfond
Ensign rfond
Ensign
Posted: ‎2025-03-18 12:25 AM
In response to Hennie_Smith
So can a fix be implemented for this issue?
ismailozinan
Commander ismailozinan Commander
Commander
Posted: ‎2025-03-18 09:51 AM . Last Modified: ‎2025-08-01 11:35 PM
4
1926
You can use convertor function with variable of item. I shared document at attached and shared  sample program that it made different method. You can reach to sample program via this link.
rfond
Ensign rfond
Ensign
Posted: ‎2025-03-19 12:03 AM
In response to ismailozinan
3
1902
But the variable's direction is "One Way" :(.
I've already tried this solution, but it doesn't work.
Quintilian_Huynh
Quintilian_Huynh
Cadet
Posted: ‎2025-07-31 09:34 AM
I’m currently working with Schneider’s Operator Terminal Expert (EOTE) as well, and although my reply is a bit delayed, I recently ran into the same issue.
My goal was to assign a value from 0 to 3 to a DINT variable in the PLC based on the selection from a dropdown list.
I initially tried using a converter, but binding the variable to the object didn’t work: it seemed to expect a Boolean.
What ended up working for me was writing an onClick script for the dropdown component that subtracts 1 from the selected index and assigns it to the variable.
Here’s an example:
onClick($GraphicObject.ModeDropDown, () => {
    LS_PmpGrp001_W.Mode.Value = ($GraphicObject.ModeDropDown.SelectedIndex -1);
Hope this helps someone else running into the same challenge.
ismailozinan
Commander
Posted: ‎2025-08-01 11:39 PM . Last Modified: ‎2025-08-01 11:53 PM
In response to rfond
2
1183
I added sample program it works with two way Link
Kris8888
Kris8888
Cadet
Posted: ‎2025-09-02 03:42 AM
983
@ismailozinan What version of EOTE was this made in?
ismailozinan
Commander
Posted: ‎2025-09-02 10:13 PM
In response to Kris8888
@Kris8888 it made by EOTE 3.5 service pack-1.
