Operator Terminal Exepert 3.3
  • Industrial Automation
  • Operator Terminal Exepert 3.3
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Operator Terminal Expert 3.1
lahiruherath
Ensign lahiruherath
Ensign
Posted: ‎2025-06-26 11:40 PM
515
Does anyone know where i could download operator terminal expert 3.3. I have the license need to switch it to a another laptop but the installation file cannot be found.
Best,
Lahiru
  • Process Automation Talks
ismailozinan
Commander ismailozinan Commander
Commander
Posted: ‎2025-06-27 11:07 PM
505
The 3.3 and 3.5 licenses should be the same. A new license is required starting from version 4.0. Therefore, you can remove the license you are currently using on version 3.3 and use it with version 3.5 as well.
https://www.se.com/tr/tr/download/document/EOTE_3_5_100/
ismailozinan
Commander
506
lahiruherath
Ensign lahiruherath
Ensign
Posted: ‎2025-07-02 08:03 PM
In response to ismailozinan
This worked. Thank you
