OPERATOR TERMINAL EXPERT - IMAGE VISIBILITY AS PER %MW VALUE
  • Industrial Automation
  • OPERATOR TERMINAL EXPERT - IMAGE VISIBILITY AS PER %MW VALUE
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Operator Terminal Expert 3.1
Bryanbyte
Ensign Bryanbyte
Ensign
Posted: ‎2025-08-20 10:36 PM
593
I'm using OPERATOR TERMIMAL EXPERT. and I want the image to appear when the value of my %MW changes. Like for example if MW=1 the valve OFB will show up, when MW=0 the valve CFB will show etc. How can I achieve this? I have tried doing script but I can't able to do it the way i wanted. Tried also the help guide it doesn't help me. Could someone help me how to achieve this. Thanks a lot
  • Smart Design & Engineering
Hennie_Smith
Lieutenant Hennie_Smith Lieutenant
Lieutenant
Posted: ‎2025-08-21 03:02 AM
2
589
Hi, Easiest way is to create converters for each state and use them on the Visibility assignment on each symbol
Bryanbyte
Ensign Bryanbyte
Ensign
Posted: ‎2025-08-21 11:36 AM
In response to Bryanbyte
i got the solution. just change from == to !=
Hennie_Smith
Lieutenant
2
590
Bryanbyte
Ensign Bryanbyte
Ensign
Posted: ‎2025-08-21 04:45 AM
In response to Hennie_Smith
586
Hi Hennie,
that is great, one thing is my concern it hides the image valve instead of showing. when the value of MW=1 only that image should show, the same with others.
I have not think that we can use the converter for this, that is very easiest way indeed.
Bryanbyte
Ensign Bryanbyte
Ensign
