Posted: 2025-06-29 06:36 PM
Hi everyone.
I'm setting up a Modicon switch (TCSESB083F23F0) and cannot get into the web browser configuration.
I get a Java Script error stating that Java Script needs to be at version 6.x.x.
Has anyone else had issue with setting these up recently. I've read elsewhere this shouldn't be an issue anymore.
Posted: 2025-06-29 10:59 PM
Hi @Ray-Klosterman ,
Try to use the tool called "Schneider Electric Viewer" to open the Web Browser of the ConneXium Switch:
https://app.box.com/s/7mtpz65mno6pcuorme856sjoovalc53q
Best regards,
Posted: 2025-06-30 01:13 PM
Hello Ray,
TCSESB083F23F0 is part of the legacy Connexium switch series which indeed uses Java for its web pages. This is a tricky issue since Java support in most new browsers is problematic. You need to use Windows Explorer web browser and have Java 7 or 8 32 bit installed on your PC (Preferably under Windows XP or Windows 7).
The easiest way is to use a virtual environment for this purpose. Sometimes it is also necessary to open the Java console and add your PC IP address to the trusted list.
Best Regards.
