ModbusTCP: SR3B261BD and SR3NET01BD
  • Industrial Automation
  • ModbusTCP: SR3B261BD and SR3NET01BD
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
akrontrols
akrontrols
Cadet
Posted: ‎2025-02-05 12:16 PM
472
I have a SR3B261BD and SR3NET01BD. I would like to monitor at least 6 inputs on/off (I1-I6) via ModbusTCP. I can't seem to find the registers for these inputs. Will monitoring those inputs only work in ladder mode?  Zelio only allows the NET01 to work in FBD. All the videos I have seen show J1XT1 with register 16 in FBD.
Do I have to purchase an additional module?
I reached out to tech support, but it is taking a little longer than usual to get a response.
  • Process Automation Talks
Bastian_Schmitz
Admiral
Posted: ‎2025-02-06 02:33 AM
Modbus TCP function is only supported if you use FBD. It seems not to be possible in LD. I got a message during the creating of a project with this hint. In any case only 4 Input and 4 Output words are supported. In your case if you want to monitor 6 Bool values you have to put them in one of the 4 WORD with CAN Block.
akrontrols
akrontrols
Cadet
Posted: ‎2025-02-06 10:47 PM
Thank you for your response.  I will give it a try.
