Modbus device (Satec PM130-Plus), modbus analog input point value cut by a date
Send InviteCancel
Posted: 2024-09-1802:30 AM
We have on a site a Satec device, PM130-Plus that connected to AS via com A, modbus device.
This device count an EP (Electric Potential) that a certain building use. The count goes from the date the this device has been connected and keep goes on so the number just keep rising higher and higher.
My question is, can I make it count the number from the first day of the month and every last day it will go back down to 0 so that I can easily see how much EP building used on that month?
