Posted: 2025-04-29 12:34 AM
Hello everyone,
I’m currently working on a BMS project where an AS-P controller is used to manage lighting and monitor alarms. For this, I’m using a Modicon M221 (TM221CE24R) with two I/O extension modules:
TM3DI16 (digital inputs)
TM3DI32K (digital inputs as well).
This is my first time working with the M221, and I need it to communicate with the AS-P via Modbus TCP so that the AS-P can read the input states and possibly write commands.
Here are my main questions:
How do I configure the M221 as a Modbus TCP slave?
How can I create and expose Modbus points (coils, registers) in the M221 program so they can be accessed by the AS-P?
Is there a default addressing table, or do I need to manually assign each point I want to expose?
Thank you in advance for your support, advice, or any example of a similar configuration!
Best regards,
Posted: 2025-04-29 11:04 PM
You have to activate manually Modbus TCP Server
And you have to map all IOs to %MW for 16Bit values (Holding Register) oder %M for (Coil).
Attached a program were I do exactly the same, but I use Modbus RTU instead.
