Management parameters for READ_VAR
  • Industrial Automation
  • Management parameters for READ_VAR
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Modicon M580
EcoStruxure™ Machine Expert - HVAC
mmaliga
Ensign mmaliga
Ensign
Posted: ‎2022-06-24 07:45 AM
2
1936
The help on the management parameters for the READ_VAR seems to be lacking some details -
I have tried to use the cancel function in an M580.  The help indicates that this is "data managed by the system" .
However, the cancel bit text below tells how to set the cancel bit as a user.
I have tried this without success.
It seems that the IN-OUT pin GEST at the bottom of the block overwrites the cancel with a "0" after I have put a "1" in it.
It appears from the instructions that I need to program it on both the input and the output pins.
Has anybody used this successfully that can lend some hints?
  • Training
Fajar_Santoso
Crewman Fajar_Santoso
Crewman
Posted: ‎2024-01-09 01:55 AM
Dear MMaliga,
Did you success this function block?
Fajar Santoso
mmaliga
Ensign mmaliga
Ensign
Posted: ‎2025-02-13 07:02 AM
I am OK with the function block.  Have many programmed and working well.  It is just the "Cancel" Input/Output  that I still don't understand.
