M580 Halt during run time
  • Industrial Automation
  • M580 Halt during run time
Bastian_Schmitz
35
LeTomas
14
RoozeeR
Lt. Commander RoozeeR Lt. Commander
6
JerryBartlemay
6
HDP
Ensign HDP
Ensign
Posted: ‎2024-08-05 08:16 PM . Last Modified: ‎2024-08-05 09:49 PM
Hello Everyone,
The M580 scan times increases and sometime it halts the PLC there no pattern or regular time for it.
But it appears that the culprit may be in AUX0. This task holds routines with some of the modbus comms items eg read_var.
I have found 2 blocks with string handling errors and arithmetic errors in AUX0, but if they were the real cause then PLC would halt all the time?.
The System word for plc error comes with #DEB0 - watchdog overrun when the plc halts and no other errors.
When the plc is restarted then only all the errors are shown again but plc stays in run mode.
Is there a way to find out what routine may be responsible for it? or way to monitor which routine, block etc is taking longest in the AUX0?
  • Asset Performance
  • Halt
  • m580
  • modbus
  • Scantimes
  • Watchdog Overrun
Replies 0
