M241 Schedule Block not working in Simulator
  • Industrial Automation
  • M241 Schedule Block not working in Simulator
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
nik500
nik500
Cadet
Posted: ‎2025-07-12 03:55 AM
578
Has anyone had any experience with ScheduleBlock Function Block in Machine Expert? I'm now trying to make the q_xOutput coil active by setting the day and time to the current day I posted. I also tried to include the set_rtc function block that has the CFCs of setting the time (I tried to match it with the Windows 10 timestamp ).  May I know what else is needed to make this function block work as intended?  or did I miss anything else? . I'm using Machine Expert v2.3(x64)
FB_Scheduling.zip
  • Connected Products
  • Process Automation Talks
Everton_Souza
Ensign Everton_Souza Ensign
Ensign
Posted: ‎2025-07-15 05:19 AM
551
Physical hardware is required to test both functions, not work in simulation mode.
In simulation mode you can read_rtc
nik500
nik500
Cadet
Posted: ‎2025-07-29 12:49 AM
In response to Everton_Souza
I didn't manage to make it work yet, even though using real hardware TM241CE40T, and I tried to make the months start and end for 12 months ( a whole year)
Test_ScheduleBlock.zip
Everton_Souza
Ensign
Posted: ‎2025-08-05 06:12 AM
Your code worked fine in my test, see attachment.
Check if your PLC time is correct.
2025-08-05 10_08_36-Test_ScheduleBlock.project_ - Machine Expert Logic Builder - Version 2.3 (x64).png
I needed to uncheck the UTC
