Posted: 2023-01-19 10:52 AM . Last Modified: 2023-01-20 01:38 PM
Hello
I'm working on communicating 1 TM221CE40T with 4 ATV930 and other M221 PLC, using modbus TCP IOScanner.
I created the configuration for the 5 channels in the PLC program but 3 of them not connected to the network right now.
I tested the program with the last two left, the result is that the communication get dropped (%SW212 <> 2) and affected the two devices connected in the network.
Do you have any suggestions to handle in a proper way the IOScanning errors and if this is the expected behavior?
Regards!
Posted: 2024-06-09 09:10 PM
hola, tengo el mismo problema, pudo solucionarlo?, y si es asi como lo solucionaste?. saludos
Posted: 2024-06-09 09:43 PM
Hola, pudo solucionarlo y como lo solucionó?, tengo el mismo problema de comunicación. Saludos.
Posted: 2024-06-12 11:20 PM
You could try if the Network Objects could solve your problem. I did not test it.
An other option could be to use the integrated functions blocks read_var write_var instead of the use of the IO Scanner. In that case you could easily activate and deactivate slaves.
