Lexium32M via NOC301 on Ethernet/IP
  • Industrial Automation
  • Lexium32M via NOC301 on Ethernet/IP
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Control Expert
HosAUT
HosAUT
Cadet
Posted: ‎2024-03-28 02:23 AM
1173
Hello Community,
I'm new to Schneider PLCs. Currently, I'm working on a project involving controlling a Lexium32 with an M580 CPU via the NOC301 using Ethernet/IP. I believe I've configured the hardware correctly since I can connect to the Lexium via the network. I would like to know where to find the GMC Independent Lexium to facilitate management. Otherwise, any solutions for ensuring proper communication would be appreciated.
Thanks in advance.
  • Process Automation Talks
  • french
HattoriHanzo
Lieutenant JG HattoriHanzo Lieutenant JG
Lieutenant JG
Posted: ‎2024-04-08 01:40 AM
Hi
The GMC-Independent-Lexium Library is not compatible with the M340/M580. Only for M241/M251/M262.
Attached you will find an example with M580 and the necessary function blocks (DFB).
Greetings
M580_Unity_LxM32_Ethernet_IP_NOC_0301_With_DFB_002.zip
