How to read input coil status with BMX NOM0200 (RS485) by READ_VAR
  • Industrial Automation
  • How to read input coil status with BMX NOM0200 (RS485) by READ_VAR
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Himanshusingh3
Crewman Himanshusingh3 Crewman
Crewman
Posted: ‎2021-07-13 01:19 AM
4092
         We are going to integrate third party equipment on Modbus RS485 through  BMX NOM0200 in M580 system, we are able to scan all Holding register, input register but how to read/scan input coil status by using READ_VAR function block????
  • Smart Design & Engineering
RoozeeR
Lt. Commander RoozeeR Lt. Commander
Lt. Commander
Posted: ‎2021-07-13 01:49 AM
4086
The READ_VAR function is able to Holding register (%MW), Input register (%IW) and Inputs (%I or 1xxxxx references) and Coils (%M or 0xxxxx references): See READ_VAR help in Control Expert, regarding the object type input on the READ_VAR function:
Type of objects to read for Modicon M340 and M580 CPU:
  • ’%M’: internal bits
  • ’%MW’: internal words
  • ’%I’: input bits
  • ’%IW’: input words
R.Roozee
Sr Solution Architect (SAE Master)
Replies 8
RoozeeR
Lt. Commander
4087
  • ’%I’: input bits
R.Roozee
Himanshusingh3
Crewman
Posted: ‎2021-07-13 02:40 AM
In response to RoozeeR
4077
Thanks for input, @RoozeeR
I have one more question how we can reset slave devices which gone in Request time out mode by auto as per preset time, because in application devices will not be online all the time only will be online when ever in duty mode.
RoozeeR
Lt. Commander
Posted: ‎2021-07-13 02:52 AM
In response to Himanshusingh3
4068
Please explain what do you mean by "how we can reset slave devices which gone in Request time out mode by auto as per preset time":
- Do you need to reset the device itself, or reset the READ_VAR function becuase of the timeout?
R.Roozee
Himanshusingh3
Crewman
Posted: ‎2021-07-13 02:55 AM
4061
@RoozeeR  not slave devices we want to reset READ_VAR FB which gone in Request time out
RoozeeR
Lt. Commander
Posted: ‎2021-07-14 12:33 AM
4044
You have to set the request timeout value in the Communication Management Parameter (Gest Input):
Please note the value given is *100 mS (10 = 1 second). Make sure the timeout value is longer than the  reaction time of the device.
With Timeout, the Function will exit with request timeout and ready for a new command.
If you set the Timeout = 0, the timeout time is infinite, so the function will not exit: Do not use a 0 value.
If this happens you can use the CANCEL function to reset .
R.Roozee
Filipe_Brito
Crewman Filipe_Brito
Crewman
Posted: ‎2022-12-08 05:10 AM
3177
Good Morning;
if I have a very large timeout, can this be a problem? I have 65 blocks of read_var and a timeout = 1000 and I am not able to read all the blocks.
chrism1
chrism1
Cadet
Posted: ‎2024-02-08 07:58 AM
In response to Filipe_Brito
2486
Did you ever fix your problem. I am currently reading 50 blocks of read_var and a timeout of 500 and i am not able to read all the blocks. Does increasing the timeout help?
MatthewM
Lt. Commander MatthewM
Lt. Commander
Posted: ‎2024-02-11 02:45 PM
In response to chrism1
I think this should be a new thread.  What do you mean by "50 blocks".  Do you mean you have 50 READ_VAR instances, or 1 READ_VAR with 1 read of 50 words, or 1 READ_VAR with 50 reads of x number of words?
