How to create a help file for a custom Unity DFB module so that "Help on Type" works?
  • Industrial Automation
  • How to create a help file for a custom Unity DFB module so that "Help on Type" works?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Control Expert
EMurphy
Crewman EMurphy
Crewman
Posted: ‎2020-11-06 01:18 PM . Last Modified: ‎2020-11-09 04:11 AM
3
3294
I have created many custom DFB for ControlExpert/Unity.  Would like to provide a help file so that when "F1" is selected on the module it appears.
  • Asset Performance
JerryBartlemay
Lieutenant JG
Posted: ‎2020-11-12 08:55 AM
In response to EMurphy
I'm sorry, no I don't.  Perhaps someone else here on Exchange has created one.  I can offer one of mine as an example, though.
Write DFB Help.zip
JerryBartlemay
Lieutenant JG
Posted: ‎2020-11-09 10:03 AM
3274
This is quite easy.  Use any editor to create your help file that can save it as an HTML file with a *.htm extension.  Locate the file in the same location as the DFB in your library.  For example, if you use the default CustomLib and MyCustomFam as library and family, store it at C:\ProgramData\Schneider Electric\Control Expert 14.1\CustomLibset\V14.1\CustomLib\MyCustomFam\ENG.  Then, when you select Help On Type for your DFB, the .htm file will open.
EMurphy
Crewman EMurphy
Crewman
Posted: ‎2020-11-12 08:26 AM
In response to JerryBartlemay
3250
Thanks.  That is what I needed.  I created a test file, and it worked  as expected.
Do you know if there is a sample template to use so that the help file is similar to the existing help files?
JerryBartlemay
Lieutenant JG
Write DFB Help.zip
