Posted: 2022-01-25 03:51 AM . Last Modified: 2022-01-25 04:08 AM
Hi.
Is there any solution how to reset password on STW6 Web panels.
Default password Admins was changed in the past and lost.
Password is needed for changing configuration.
Thanks.
Posted: 2022-01-25 04:55 AM
It's not possible to make a factory reset on the STW6X00 panels. You could try to contact technical support in your country.
Posted: 2022-01-28 01:03 PM
As already mentioned the HMISTW6 password cannot be reset in the field.
The HMISTW6 would need to be return to the nearest Schneider Electric Repair centre so that specialised equipment can be used to reset the entire unit to factory defaults.
