HMIST6700 can show webvisualation of M241 PLC?
  • Industrial Automation
  • HMIST6700 can show webvisualation of M241 PLC?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2021-09-30 04:23 AM
1946
I have a M241 PLC with a complex webvisualation from my technology.
I want to see this webvisualation on the HMIST6700 device. To do this just for first testing I used WebBrowser object in the EcoStruxure Operator Terminal Expert.
When I started the HMI I saw on the screen only "Browser object not supported on this target". What was I do with wrong? Is it possible to do this application or not?
Thank you the anwares!
  • Smart Design & Engineering
  • Training
Svenmj
Ensign Svenmj Ensign
Ensign
Posted: ‎2021-10-01 12:49 AM
1933
The Panel does not support EB-Browswer. Depending on your application you could use HMISTW6700, WEBbrowser Panel which does not contain any HMI application, but only browserHMIST6700_WEB.png
Svenmj
Ensign
Posted: ‎2021-10-01 04:48 AM
In response to Anonymous user
Hello
In the EOTE Help, select Feature Guide. Browser opens, select panels you want to see, Show resultFeatureGuide.pngShowFeature.pngFeatureGuide.pngFeaures.png
Svenmj
Ensign
1934
Posted: ‎2021-10-01 03:36 AM
In response to Svenmj
1928
Thank you for helping! Where you find this table?
Svenmj
Ensign
Hello
