Facing delay while opening the faceplate in EcoStruxure Process Expert V2023
  • Industrial Automation
  • Facing delay while opening the faceplate in EcoStruxure Process Expert V2023
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Process Expert
ravi_kaneria
Lieutenant JG ravi_kaneria
Lieutenant JG
Posted: ‎2024-10-09 04:44 AM . Last Modified: ‎2024-10-09 10:58 AM
4
1429
when we try to open the faceplate by clicking the pump icon then we face delay while opening the faceplate.
please check in below attached video
  • Smart Design & Engineering
Replies 4
Sumanjith.an
Sumanjith.an Support
Support
Posted: ‎2024-10-14 02:27 AM
1337
The issue could be due to the slowness in communication between the controller & the plant SCADA
You can check the following
1. Tuning to be in the ofs communication
2. Check the Network bandwidth
ravi_kaneria
Lieutenant JG
Posted: ‎2024-10-14 07:16 PM
In response to Sumanjith.an
Can you please elaborate the tuning the ofs and how to check network bandwidth?
ravi_kaneria
Lieutenant JG
Posted: ‎2024-10-14 08:08 PM
we understood to tune the OFS means we need tune the OFSScantime ? as per attached document
Sumanjith.an
Support
Posted: ‎2024-10-15 12:16 AM
Basically, It's a performance related issue and there are several parameters to be checked.
Few are listed below
1. Optimizing Controller’s Scan time
2. Make sure the CPU load is below 50%
3.Max channel, max pending configuration needs to be done by checking the CPU capacity
4.Configiration OFSOPC group Update rates and its tuning according to the plant requirement
5.Make sure the architecture is designed to accommodate the network bandwidth for PLC communication
