FCT Type Not Found in Library – Premium PLC ( Control Expert)
  • Industrial Automation
  • FCT Type Not Found in Library – Premium PLC ( Control Expert)
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
SESA791317
SESA791317 Cadet
Cadet
Posted: ‎2025-09-11 08:59 AM
309
Hi everyone,
I'm currently working on a project using Premium PLC in Unity Pro / Eco Structure Control Expert, and I'm encountering the following error:
"FCT Type not found in library"
This happens when I try to open or compile the project. I suspect it might be due to missing custom libraries or EFBs. Unfortunately, I don’t have access to the original library files.
  • Has anyone faced this issue before?
  • Is there a way to obtain the missing libraries?
  • Any workaround to open or migrate the project without those FCTs?
Thanks in advance for your help!
  • Process Automation Talks
  • Smart Design & Engineering
Fleo
Ensign Fleo
Ensign
Posted: ‎2025-09-16 05:29 AM
These functions come from the TCP Open Block library.
This library was not free and it is not available without a subscription, I believe.
Without this library, you can "build changes" but not "build all".
If you are using a different version of Unity Pro or Control Expert, then use the STA file.
Fleo
Ensign Fleo
Ensign
Posted: ‎2025-10-07 09:00 AM
I finally found that the library is available (downloadable) in this FAQ: How to install TCP Open V4.0 Libset in CE V15.0?
