Ecostruxure process expert for ASP , HELP !!
  • Industrial Automation
  • Ecostruxure process expert for ASP , HELP !!
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Process Expert for AVEVA System Platform
AVEVA Group PLC
Schneider_x3
Crewman Schneider_x3
Crewman
Posted: ‎2025-03-24 05:00 PM
507
Hi guys
I'm just looking for which licenses i will need to run an EPE for ASP ?
I’m also wondering about installing softwares ,if I only need to install the system server, Control Expert, and Aveva System on the Engineer station, and only the Aveva System on the OS clients?
Your help would be greatly appreciated 😁
  • Process Automation Talks
  • Aveva System Platform
  • Ecostruxure process expert for Aveva system platform
  • EPE for ASP
Sumanjith.an
Sumanjith.an Support
Support
Posted: ‎2025-10-23 02:50 AM
Hello
 The main component of EcoStruxure Process Expert is the System Server. The server embeds the repository of the application that is designed and running on site.
The Engineering Server license includes the licensing of the server itself, and all the companion software that contributes to the solution offer:
  • EcoStruxure Control Expert
  • EcoStruxure Control Expert Asset link
  • Application Instances
And:
  • 1x Engineering client
  • 1x Diagnostic client
It is possible to design an application that doesn’t exceed 10 000 (EUSPEPCZLSPEZZ  ) object instances.
This is a permanent license, which can be updated to a new version of the software through and update part number .
Main componet for EPE for ASP are as follows
  • Engineering server; Repository of the application. it includes one engineering client and a diagnostic client
  • Engineering clients (optional); to add engineering client, for example to access / modify the application from several locations on the site
  • Diagnostic clients; to get advanced diagnostics in parallel from several Operation clients; It require a Diagnostic Client on each Operation client
  • Operation server(s); part of the AVEVA System Platform configuration
  • Operation Clients (s); part of the AVEVA System Platform configuration.                                          Regarding the installation, all the components will be installed when you run the setup. No manual installation is required for the components.
