EcoStruxure Operator Terminal Expert
  • Industrial Automation
  • EcoStruxure Operator Terminal Expert
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EdW92
EdW92
Cadet
Posted: ‎2024-05-31 05:56 PM . Last Modified: ‎2024-05-31 06:04 PM
3959
Hi
I'm trying to download new software with EcoStruxure Operator Terminal Expert to an HMIDT351+HMIG3U with loaded Vijeo firmware V6.3.0.1007(Ecostruxure Machine Expert). Every time I get this Error popup with the USB route. below is an attached picture.
EcoStruxure Operator Terminal Expert-> Download Failed Communication error occurred: message not received
With the Ethernet route, I get this Error Popup.
EcoStruxure Operator Terminal Expert-> Unable to connect to the specified destination, Check if the target machine is in project transfer standby.
What else am I missing?
@LeTomas
@JerryBartlemay
  • Connected Products
  • Process Automation Talks
Replies 5
LeTomas
Lt. Commander
Posted: ‎2024-06-03 03:23 AM
3957
Hi @EdW92 ,
Based on your pictures the HMI has the VJD firmware on it. I recommend you to use the recovery of the HMIG3U along with an EOTE image.
The process for the recovery:
https://www.se.com/uk/en/faqs/FA242275/
In order to get the EOTE image for that target i recommend you to contact the Technical support team so they can get the right image for you.
I have found this image on my pc...but it is under your own risk to test it:
https://app.box.com/s/51r9guqqyaefxforic86z4jb46re6vln
Best regards,
Note: Have you tried using the mini-usb cable?
EdW92
EdW92
Cadet
Posted: ‎2024-06-05 10:50 AM
In response to LeTomas
Hi LeTomas
I also tried the mini USB port, but it didn't work.
But I changed the PC Firewall to allow all Outbound and Inbound connections with the program filter pointing to the EcoStruxure Operator Terminal Expert.exe file. It seems to work now. thanks for the information.
I attached a screen snippet of the inbound rule.
Metskurat
Metskurat
Cadet
Posted: ‎2024-12-04 10:35 PM
Hello
I have the same problem as the topic starter, I can't send the program to the HMI. I also tried opening ports, changing IP addresses and turning off the firewall, but I still get the same error messages. USB doesn't work at all.
I'm using: WIN10, PLC is M221 and HMIST6400.
Sending the program to the PLC works fine, but I can't connect to the HMI.
How can I solve the problem?
All the best
Alar
dalporto
dalporto
Cadet
Posted: ‎2025-09-03 12:22 PM
I have the same problem right now. It's working fine with 3.4 version, now I cannot download on 3.5.
I opened the ports, even disabled the firewall, still no luck.
dalporto
dalporto
Cadet
Posted: ‎2025-09-03 01:30 PM
I tried opening the ports, that wasn't it. The problem lied within VMWare USB configuration that needs to be set to USB 1.1.
Hope that helps someone one day.
