EcoStruxure Operator Terminal Expert V3 dynamic objects
  • Industrial Automation
  • EcoStruxure Operator Terminal Expert V3 dynamic objects
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Operator Terminal Expert 3.1
gyorgy_roland_c
gyorgy_roland_c
Cadet
Posted: ‎2021-10-15 02:03 AM
4527
Is it possible to create dynamic groups or contents that accept variables as parameters in EOTE? Those variables would change visibilities, or even colors of items, e.g. circuit breaker open-closed states, motor run or stop states.
Bastian_Schmitz
Admiral
Posted: ‎2021-10-18 10:34 PM
Hello Roland,
If you group several object you could change the visibility of this group via one variabel or via script.
You must only add a variabel at the visibile attribut.
If you want to change colours globally in your project you have the possibility to work with variabels instead of constances.
If you use a variabel for a colour. You could use a global script which defines the value of this variabel in combination with the status of your PLC program. In that case you could easiely globaly adapt objects.
Paul_Derbyshire
Ensign Paul_Derbyshire Ensign
Ensign
Posted: ‎2021-10-17 07:56 AM . Last Modified: ‎2021-10-17 08:17 AM
Hello @gyorgy_roland_c ,
Using EcoStruxure Operator Terminal Expert v3.2 SP1 or earlier parameters are not supported.   Instead, please use an array and change the index of the array.
For example, you can have 1 or more custom arrays of the items you need to work with:
  • MyArray[0] = PLC 1, tagname/address = Torque
  • MyArray[1] = PLC 2, tagname/address = Torque
  • MyArray[2] = PLC 1, tagname/address = Speed
  • MyArray[3] = PLC 2, tagname/address = Speed
Create an integer tag called, MyIndex
Within the switch, lamp, visibility  etc. use = MyArray[MyIndex]
Now when you change the value of MyIndex you can switch between different PLCs and tagnames/addresses.
If you require a specific project example please respond with your specific need and I can develop one for you.
Paul Derbyshire
Senior Product Application Expert | Sales Enablement | HMI Line of Business, Digital Factory | Industrial Automation Business | Schneider Electric
  • addressing
  • array
  • eote
  • indirect
  • parameter
  • tags
  • variables
Bastian_Schmitz
Admiral
Hello Roland,
