Division in Ladder for Zelio Logic
  • Industrial Automation
  • Division in Ladder for Zelio Logic
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2020-12-30 03:34 AM
2699
Hello
How can I use multiplication and division  in Ladder programming language for the "Zelio" Logic products  ?
  • Smart Design & Engineering
Fleo
Ensign Fleo
Ensign
Posted: ‎2021-01-05 05:07 AM . Last Modified: ‎2021-01-05 05:10 AM
In response to Anonymous user
Arithmetic functions are only available in FBD language.
In LD language only comparisons are possible.
All functions are explained in online help of Zelio Soft.
Replies 4
Posted: ‎2020-12-31 04:01 AM
2693
Basic Ladder Logic instructions allow very simple logical decisions. Arithmetic Ladder Logic instructions go beyond the simple true or false operation to give the ability to more complex operations. It retrieves one or more value, perform an operation and store the result in memory.
There is a very close relation between math instruction and some of the control status bits. After a math instruction is executed, the arithmetic status bits in the control status file are updated. Control status file is the data file "S2 - Status".
  • S:0/0 Carry (C) Sets if carry is generated; otherwise it is cleared.
  • S:0/1 Overflow (V) Indicates that the actual result of a math instruction does not fit in the designated destination
  • S:0/2 Zero (Z) Indicates a 0 value after a math, move or a logic instruction
  • S:0/3 Sign (S) Indicates a negative value after a math, move or logic instruction.
  • S:5/0 Minor Error Minor error bit is set upon detection of a mathematical overflow, or division by zero. This error can cause a CPU fault, which could be avoided if the bit is unlatched before the END, TND, or REF statement.
  • S:13S:14 Math register
  • S:13 -Contains the least significant word of the 32 bit values of MUL, DDV, FRD, and TODS:14 -Contains the Most significant word of the 32 bit values of MUL, DDV, FRD and TOD.
Posted: ‎2020-12-31 11:38 AM
2679
HI Covey
Thanks for your answer. But I can't find any reference to  arithmetic functions for Ladder at the "Zelio Logic Programming Guide". File name EIO0000002612.01.pdf      10/2017.
Is there any other reference for Ladder programming comprising arithmetic functions ?
Any help would be appreciated.
Happy new year.
Manolis Logiadis
Fleo
Ensign Fleo
Ensign
mydg22
Crewman mydg22
Crewman
Posted: ‎2022-10-19 02:22 PM
buenas tardes , ese tipo de programacion solo se utiliza en BDF, y en equipos que puedan ser programados con  los dos tipos de lenguaje ladder, bdf, primero debes revisar el hardware si tiene esta forma de programar para luego aplicar esas funciones aritmeticas en tu equipo. no toda la serie SR2 tiene  la ofrma de programación BDF
Magda Diaz
