Custom emergency push buttons
  • Industrial Automation
  • Custom emergency push buttons
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
electrician2025
electrician2025
Cadet
Posted: ‎2025-01-29 12:35 AM
713
Hi, I am looking to replace an emergency push button in a control panel. I could only find emergency head : Harmony XB5 Emergency stop head switching off, plastic, red mushroom 40mm, 22mm, trigger latching key release ,Item Number: ZB5AS944. Has anyone being able to customise the key? I am looking to get it match with my Earth switch.
  • Smart Design & Engineering
Hennie_Smith
Lieutenant Hennie_Smith Lieutenant
Lieutenant
Posted: ‎2025-01-29 08:53 PM
Hi, There are a couple of key options available. Check if your Earth switch has any of the following numbers. The code below is appended to the base part ZB5AS944
You could request a specific key number as well if none of these are the same as your earth switch but you will need to contact your regional Schneider office.
Eric_GR
Lieutenant JG Eric_GR Lieutenant JG
Lieutenant JG
Posted: ‎2025-01-30 01:56 AM
Hello yes it's possible by a special request here: https://www.se.com/uk/en/work/support/
