Control Expert V14.1 FBD Editor
Select a Country
  • Industrial Automation
  • Control Expert V14.1 FBD Editor
Bastian_Schmitz
Bastian_Schmitz Champion
38
LeTomas
LeTomas Mentor
14
ismailozinan
ismailozinan Leader
8
Posted: ‎2020-03-17 02:56 PM
5119
I'm having an issue with the FBD Editor in Control Expert V14.1.
Note: My colleagues have the same issue.
The FBD Editor is not allowing me to click and select the input/output pins of a FB.
Instead when the left mouse button is pressed, the cursor changes to that shown when the "Link" tool is selected.
Below a screenshot of the cursor when the left mouse button is clicked.
image.png.
In previous versions of Unity Pro a single left mouse button click on a FB input/output pin selects the pin.
Has anyone else had similar issues?
Does anyone know of solutions to this issue?
  • Smart Design & Engineering
Posted: ‎2020-03-17 08:21 PM
Speaking to Schneider Tech Support, they advised that to select a FB pin you must click on the pin description inside of the FB square.
Clicking on the FB pin itself will begin creating a link to another FB.
This is a new 'feature' that first appeared in V13.0.
Richard
Richard Troubleshooter
Troubleshooter
Posted: ‎2020-03-18 03:44 AM
1
5100
So basically:
  • Click the pin if you want to make a connection to another pin/function block
  • Click the label to select the pin - for example if you want to invert it
  • Double-click either to be attach a Variable to the pin.
Hope this helps.
Richard
Richard
Troubleshooter
Posted: ‎2020-03-18 03:50 AM
In response to Richard
Oops ... and one more I forgot is that you can right-click either to get the options menu.
Richard
