Posted: 2025-03-05 05:59 AM
I have permanent Control Expert 15.1 license, time on time I receive a message that no license available, I tried to return the license then delete the files in "C:\ProgramData\FLEXnet" folder then install the license, it will work for some time and as long as CE is running, but if we close CE and re-launch it , the same problem raise again. I have to repeat the same procedure or simply restart the PC to get a valid license again.
Any idea how we can resolve this issue for good?
Posted: 2025-03-05 06:18 PM
Posted: 2025-03-05 10:36 PM
I will try this.
Thanks for your reply
Posted: 2025-03-05 11:42 PM
Did you try the "Repair" button?
Posted: 2025-03-06 12:43 AM
Hello @AhmadHouhou
Could you share us any screenshoot of the license Manager and the popup of CE15 that asks to license? Which Version of LM do you have?
BR
Ricard
Posted: 2025-03-06 12:57 AM
Hello Richard,
Thanks for your reply.
I have re-activated the software and until now it is still working and can't capture the error, but the message was "control expert failed to find a valid license"
Please find below LM screenshot.
Best Regards
Ahmad
Posted: 2025-03-06 05:10 AM
No, I will try it if it will happen again
Posted: 2025-03-06 08:41 AM
Not sure how a "alliance softpack" work but mine say version "15" which means all 15.x versions. You have "2022" which looks like a year to me. Is this licens still valid 2025? Maybe "alliance softpack" is issued per year?
Posted: 2025-03-06 11:43 AM
It is permanent license, I guess it is valid for all 15.x versions regardless of the year, we will need another license for version 16.x
Posted: 2025-03-06 11:42 PM
hello @AhmadHouhou
Here we have several issues.
The CE15 license is valid for all other versions 15.0,15.1,15.2, and 15.3
For the alliance pack version you should have a CE15.x license
The part number is correct EUSL22CZZTPTZZ
The only thing I can see is that there is something wrong with the installation of the Floating License Manager / License Manager or the Expert Control. Remember you must have LM and FLM both software
If not, contact SRC via email so they can verify the CE versions that your license ID has, but I am sure that you have CE15.x
On the other hand, it would be nice to see the error
I'm attaching the links of LM and FLM
Posted: 2025-03-07 12:03 PM
Thanks, Ricard, for your reply.
I uninstalled CEV 15.1 and installed CEV 15.3. It worked for some time, but the same issue occurred again.
I then installed LM V3.0 and activated the CE, but the license was unavailable, and I received the following error. After restarting the PC, the CE was activated.
Now, I will wait for some time, and if the same issue arises again, I will contact the SRC.
Best regards
Posted: 2025-03-12 05:28 AM
Looks like you have floating license and not node locked. Is your floating license server on the same machine where you try to use Control Expert?
